What version of JAVA is needed to run version 8.2?
This is from the 8.2.3.0 installation guide
JVM Not Delivered with Arbortext Editor
Arbortext Editor does not ship with Java Development Kit (JDK). You must
obtain JDK from Oracle (https://www.java.com) or from Amazon and install it.
Arbortext Editor will work with Oracle Java 17 and Amazon Corretto 17.
Bryon
This is from the 8.3.1.0 installation guide
Arbortext Editor will work with Oracle Java 21 and Amazon Corretto 21.
Bryon
As others have said, you need install Java separately. I am using the Termurin build (from the Eclipse Foundation), so I do not think it has to be either Oracle's or Amazon's build, as long as you get the Java version mentioned in the documentation.
If you plan on building your own extensions, make sure the version of the Java compiler matches what JVM version mentioned in the documentation, otherwise you may get compiler errors when linking to aom.jar.
Dear Customer,
Please refer this link for (Arbortext Editor/Styler/PE 8.2.3.0 Release Matrix) https://release-advisor.ptc.com/releaseMatrix?releaseId=1681 where it's mentioned that 'Amazon Corretto 17 and Oracle Java 17 are supported.
Please let me know if you need any other details. Thanks.
Manpreet Singh
Hi @BD_12998185,
Anurag
