Multiple header rows in (one) custom table
Hi!
Is there a way in Arbortext with Styler, when making a custom table, to make more than one header row for that table? In other words, the header would be two rows.
There doesn't seem to be a way to do this via the Styler interface i.e. Custom Table tab. Perhaps there's a way involving editing the APP source ...
It would also be convenient to be able to merge cells in the header row. There doesn't seem to be a way to do this in the Custom Table tab either.
Someone might suggest, use a standard table! Unfortunately this isn't possible in this particular case. (I intend not to modify the DTD I am using.)
I appreciate your consideration.
