QuickTag Menu Bug in Docmap v6.1?
  • July 22, 2014
  • 0 replies
  • 516 views
There seems to be a problem with the document map window when inserting an element using the Quicktag menu.Using just the sample 28001C.sgm document from the Arbortext distribution with the following snippet of structure:
<para0><title>Definition of terms</title>
<subpara1 id="attname.def"><title>Attribute name</title><para>The
name of an attribute as assigned in the attribute definition list
declaration of a DTD.</para>
</subpara1>
<subpara1 id="border.def"><title>Border</title><para>Graphic that
appears along page boundaries. </para>
</subpara1>
<subpara1 id="charfill.def"><title>Character fill</title><para>The
repeated use of a character (possibly the space character), or string
of characters, to occupy space within running text, for example, leader
dots.</para>
</subpara1>
</para0>
In the Docmap, if I right click after the last </subpara1> before </para0> the QuickTag menu comes up and I can successfully insert another para0 at that point. But, if I right click after the middle </subpara1>, the cursor jumps to before the start of the first <subpara1> and then the QuickTag menu comes up. This results in the new element being inserted in an undesired place.
Can anyone give me some feedback on this? Has this been identified? Any workarounds? This did not occur in v5.3.
Jeanne
