Has anyone noticed differences in how text wraps to the next line in version 6 versus older versions? I'm seeing many differences between outputs from 5.3 and 6.0. I can't account for anything in the markup causing the difference. Has anyone else noticed this?
Glad to hear I'm not alone...I think!
I'm seeing wrapping differences throughout. I started noticing it in captions and then looked at normal text and the wrapping is different in almost every paragraph. Could it be hyphenation or widow/orphan control logic differences? I'm thinking there is no magic bullet for this one.
On a side note, we had been using Acrobat document compares and it didn't catch any of the wrapping differences. Luckily, we also did a visual compare.
In Reply to Sarah Price:
Be afraid be very afraid.
Also I don't know what graphic type you use but our biggest issue has been around graphics. We use .cgms. The IsoView application doesn't work as well as the Larson Utilities application they had in the previous versions. It is very slow and we have had problems with arbitrary crashes during publishing. A new release is expected to be out June 27 to correct the crashing but I still think there will be speed issues. A 5,000 page book with 2,000 graphics went from approximately 8 minutes to 2 ½ hours to publish. L!
