Understanding Bursting File(.bcf)
  • June 22, 2015
  • 2 replies
  • 4614 views
Hi Experts,
I am finding it difficult to configure bursting files. Any change made to the .bcf are not reflected the CMS.
I am trying to burst my bookmap document into chapters when they are stored in Windchill, but I am not able to do so.
Please help me understand how this burst configuration concept works.
I have created a new bursting folder and added it to the system variable as APTOBJCFG.
I am uploading the .bcf files I am using.
    Best answer by JeffStevenson
    Glad you got it to burst at the chapter.
    Looking at your bcf, you have a leading "/". This isn't necessary because the adapter will look within the current context where the user is signed into. It is a relative path to the root folder of the product or library. So, if your context is a library named "Arbortext_Test", then your location would simply be Arbortext_Test/topics.
    Further, I didn't see any namerule or typerule definitions. If you don't have any subtypes, then typerule isn't necessary, but I would assume you would want to control the name of the bursted content with namerules.
    Hope that helps!
    -Jeff
    Have you configured a burst log? This will help triage issues with burst configuration.
    Set a Windows env. variable called APTBURSTLOG to a location you can access. It must be a fully qualified path with a filename (i.e. C:\burst.log).
    There are other log files you can set, too, but this is a good one to start.
    Set the burst log and run the job again. Post back the log results if you still have trouble.
    -Jeff
    hmungekar1-VisitorAuthor
    Hi Jeff,
    This are my burst logs
    What version of Arbortext are you running? It should tell you which config files are being used.
    HI Jeff Stevenson‌,
    I was able to burst my bookmap into chapters after adding the chapter element in the boundryspec as you said, but I am still not able to store the chapters in a preferred location . I have attached bcf files and the burst logs. Please help me to solve this problem .
    Thanks in advance.
    Hope that helps!
    -Jeff
    Thanks buddy. Now everything is working as per the requirement. Ya I need namerules I will define it now.
    Thank You Jeff
