Hi everyone,
We want to use Arbortext Editor 6.0 with Eagle S1000D solution.
We install EPS Plugin for Arbortext Editor.
While opening, Arbortext Editor gives an error:
Then, in Arbortext Editor, we can see the EAGLE menu in toolbar (02.PNG)
When we click to EPS Plugin in EAGLE menu, we gets another error (03.PNG)
[A30165] com_call: invalid or undefined interface ID 0
(at line 46 of file "C:\Program Files\PTC\Arbortext Editor\custom\init\EAGLE.ACL")
Function traceback at time of error:
#1 Artwork() at "C:\Program Files\PTC\Arbortext Editor\custom\init\EAGLE.ACL":46
In row 46, you can find: "local login_result = com_call(EAGLE_Handle, "Login", dirname, filename, version_number);"
Is there anyone facing same issue before and/or have any opinion about solution?
Best regards,
Erkan OKUR
This is a known issue with the EAGLE/EPS Plugin installation. [FIX] = Go to the EAGLE/EPS install directory (default = C:\Program Files\RSC\EAGLE 2B ELT [32 bit OS] or C:\Program Files(x86)\RSC\EAGLE 2B ELT [64 bit OS]) and run the EPS_Plugin_Install.exe and make sure that it points to the CORRECT Arbortext Editor install directory when the install prompts you. This will fix this issue.
Mike Dunn
Team EAGLE
