Which one is better? IsoDraw and Creo Illustrate
  • April 15, 2016
  • 2 replies
  • 5737 views
I am working as an technical illustrator. I installed some softwares as following.
  • Autodesk Inventor
  • PTC Creo Parametric
  • PTC IsoDraw CADprocess
  • CorelDraw
  • Windchill
  • Arbotext Editor
I have two working process
  • Open 3D model in Inventor  > Create 2D drawing as CAD file > Open the drawing in CorelDraw > Modify the drawing and export it to SVG
  • Open 3D model in IsoDraw > Create 2D drawing as CGM > Open CGM in CorelDraw > Modify the drawing and export it to SVG
I upload SVG to Windchill one by one.I think it will be easy to use if there is a link between Isodraw and Windchill.
There are two choices for me. IsoDraw and Creo Illustrate. I want to know which one is better.
Thanks.
br, Lily
Best answer by VladimirN
To say briefly - these software products are designed for a slightly different purpose:
  • Arbortext IsoDraw - for creating 2D technical illustration (it has a good functionality for these purposes);
  • Creo Illustrate - for 3D technical illustration (including 3D animation).
Or you mean - better for connecting with Windchill PDM?
P.S. But apparently the functionality of both programs eventually merged into one new software.
VladimirN24-Ruby IIIAnswer
lguo1-VisitorAuthor
thank you very much.
I think they are both easy to connect Windchill PDM.
Did you find the responses helpful? If so, could you let the community know by selecting Correct for the answer that assisted you most?
Thank you.
