how can i set the different column width in the style sheet for the table?
there are three tables which are finished by three guys, but the column width is different in different table, can i set the column width in the style sheet to keep them accordance? thanks!![]()
Maybe this will help, in editor we created a table then made a tag template (Tools, tag tempaltes) out of it. That way each author can insert a table that is the same size and populate it with there own content.
In the default Arbortext setup, table widths are controlled by attributes in the table markup. You cannot set the column widths in a stylesheet.
I think your best bet would be to insert something in the publishing pipeline which "normalises" table markup before it is published. That step would simply modify the table width attributes in order to produce the desired, standardised result.
