pasting text into default para /p tag
  • December 7, 2018
  • 4290 views
Hi..i was wondering whether i can copy/paste text by default into its own para/p tag. Are there any settings for this ? Currently, when i paste text there is no tag  (unless pasted in an existing p tag) and the para/p tag has to be added individually. Thanks !
You can specify this in the .dcf file (doctype configuration file), which is located in the same directory as the .dtd file.
The relevant element in the .dcf file is <ElementListItem>, which is within the <InsertAroundToFix> element, which is within the <ContextTransformations> element. You will have to insert any of these elements that are not already present.
Set the element attribute on <ElementListItem> to the name of the tag you want to be automatically inserted when you paste text. For example:
<InsertAroundToFix>
<ElementListItem element="para"/>
HTH!
Suzanne Napoleon
www.FOSIexpert.com
"WYSIWYG is last-century technology!"
I'm  not able to locate the folder. Could you help me please with the location. Thanks !
I've attached a screenshot of the folder at my end. Which folder do i go into. I'm unable to see the tags that you mentioned. Also, could you possibly attach a screenshot of the file and include the changes to be made. That would really help me know whether i'm on the right track. Thanks a ton!
