spellcheck and brk tags
douglaswade1
I know the spellcheck improved after 5.1, and can detect when there are
missing spaces between elements. Is there a way (e.g., editing .dcf) to turn
off that boundary around the element <brk> check. I do not want to add
spaces near the <brk> tag, but I do not like it looking like the words
around the <brk> tag are misspelled.
d
Hi Doug-
Try adding an <elementoption> element in your DCF for the "brk" tag (if
it's not already there), and set spellCheckingNewWord="yes". I think
that should do what you want.
<elementoption element="brk" spellcheckingnewword="yes"/">
--Clay
Clay Helberg
Senior Consultant
TerraXML
beautiful, works... I was using those settings, but added a few others
attributes and that did not work. I reset them all, and only use
spellCheckingNewWord then it worked.
d
