Creo 1.0 Simulate Issue - "Model is insufficiently constrained"
Hi, I am trying to run a simple stress analysis on an assembly using a static analysis, but I keep getting the error:
"The model is insufficiently constrained for the analysis. Please review the element connections,
properties, and constraints in highlighted entities. If this is a modal analysis, then you may be
able to obtain a solution by requesting additional modes."
Total Assembly:
Latch:
Pin
Error
I have defined:
-materials
-surface-surface contacts
-hole constraint in all directions on latch
-surface constrait on all pin surfaces in all directions, except X (same direction as load)
I tried doing the same analysis on a single part (rather than an assembly) and it works fine.
Does anybody have any ideas how to resolve this issue?
Thanks a lot
Mark M.
