Adding testcases to codebeamer via azure pipeline.
  • June 7, 2024
  • 862 views
I am trying to add testcases created in xml file and importing them in codebeamer from a github repo but unable to proceed due to a following error-
##[error]Unhandled: Configuration error, please check instance is available and test configuration is correct
what is the actual cause of the error I am not able to figure out?
Best answer by alfonso_c
On the support ticket raised after this forum post, we discussed that the error is thrown by this tool: https://marketplace.visualstudio.com/items?itemName=IntlandSoftware.codebeamer&targetId=14f724f0-e508-42f4-acf4-2220f2507724
This is a third-party tool and not an official PTC Codebeamer integration, it is the result of the individual effort of certain developers and it might not be compatible with newer Codebeamer versions. I documented the topic at: https://www.ptc.com/en/support/article/CS419989
alfonso_c14-AlexandriteAnswer
