Hello everyone,
I want to use the Codebeamer server (2.2.0.1) as an OSLC server, and I have trouble to do so.
First I followed this Server Guide and added a new section to the Application Config:
"apiThrottling" : {
"urlPatterns" : "/api/oslc/**",
"bandwidthConfigs" : {
"capacity" : 100,
"timeUnit" : "SECOND"
I saved it, and it said "saved and re-applied" or something like that. Seems like it shall be ready.
Then I try from my browser (which I login to codebeamer already) the following url:
https://my_codebeamer:8080/cb/api/oslc/catalog/projects
Also tried this
https://my_codebeamer:8080/api/oslc/catalog/projects
Both shows connection timed out.
Do I need to setup port 8080 for oslc, or is it the default (fixed) port? Did I miss anything here please?
Thank you very much in advance.
Hello RR_12247123
Thank you for posting the topic!
Except apiThrottling parameter, there are other two settings need to be check: contentSecurityPolicy or CB_CORS_ALLOWED_ORIGINS, and mail
Please refer to the following article:
https://www.ptc.com/en/support/article/CS400634
In addition, please use Postman to access "GET https://my_codebeamer:8080/api/oslc/catalog" with Basic Auth.
Best regards,
Ivy
Hello RR_12247123
Best regards,
Ivy
It turns out I don't need the port number here. After adding the contentSecurityPolicy, I can use curl to access /api/oslc/catalog/projects.
Also you are right, I need to use curl, the browser doesn't work for the OSLC api GET.
