2 Projections
MuhammadAnwer
2 Projections
Dear friends In Pro E 2001 a very advance and helpful command 2Projections, My question is where is in WF3. Thanks[/b]
go to menu mapper in help, release 2001 to wildfire 2
Select both the curves using 'CTRL" key and then #Edit >> Intersect. Hope this helps.. Rameet
Be aware that the resultant curve is NOT in some cases the same as it would have been using the older versions. The new algorithm(s) result in different geometry. I believe this change occurred from WF2 to WF3.
