Balancing the model in Mechanica
  • November 19, 2007
  • 2192 views
Hi all, How do we check whether model is completely balanced or not in Mechanica??
    I don't think you need Mechanica for this. If you use: Analysis>Model>Mass Properties You can chech whether the centre of gravity is on the model axis.
    Hi Andy, Thanks for your reply. Balanced model means, I am thinking with respect to the loading & constraints. I am trying to find out whether all the conditions and loads applied are good enough to give proper results, and the model is in equilibrium comdition. Please let me know if any method is existing. Shekar
    November 19, 2007
    In Mechanica, you can use: Info>Review Total Load to check whether your loads balance.
