Blank Development
  • October 17, 2012
  • 3802 views
Not able to develop blank or flat form for this model.
Kindly help...!!!
    Maybe it's better to use special application for this purpose, such as BlankWorks...
    ssharma-21-VisitorAuthor
    But i have to do it in Creo Parametric Only.
    I don't believe that flattening a quilt will give you a trustworthy result, because the shape of the blank in this case depends on the origin point and datum points on the quilt boundary, you have chosen. And, I should say, it changes dramatically.
