Blends-getting rid of twists-start point is not there!
In experimenting with some simple BLENDS, I often find unwanted twists in the finished Blend between sections. This is easy to fix by dragging the start point on the section.
When I create Blends from existing sketch sections, this works fine.
However, when I create BLENDS and then create sections inside the blend, there is no sign of the start point. Without the start point, I cannot fix the unwanted twists.
Does anyone else experience this? Should I just recommend to my class (high school) that they create Blends from existing sketches? Or is there a way to get the start point to appear on Blends with internally defined sketch sections?
Thanks for help on this.
-Brett
