Cannot delete lines from sketch
Creo Parametric 3.0
I have a "shape" inside of a sketch that also contains other shapes.
The shape in question has 6 different sides.
No matter which order I choose I can only delete 4 of the lines.
Two of the lines (the last two left) cannot be deleted.
One time its the upper left two corner lines, next time I try it's the bottom two in the lower right corner,
next time I try I'm left with the bottom most line and top most line.
IT IS NOT THE SAME LINES EVERY TIME.
When I get to the last two I get "Invalid Selection, try again"
I've tried the DEL key, RMB -> Delete NOTHING WORKS.
I am about ready to put my fist through my monitors!!
I'm pissed, this is BFS!!!
Please help!
