Creo 4 Sketcher circle constraints show "=" sign compared to Creo 3 and previous versions
- October 10, 2017
- 1 reply
- 1670 views
I have been using Creo 4 for a while now and noticed that in sketcher when drawing holes you get and "=" sign for a hole that matches a hole that you created. My problem is that when I'm in sketcher I usually have a fair amount of holes of different sizes. When the equal sign shows up its for any size hole I recently created which makes it impossible to correctly draw the right size hole if they are close together with the same size. In Creo 3 when creating holes in sketcher it would reference a number that corresponds to each hole when the constraint popped up so that you could match the hole you wanted . Anyone know how to fix this in Creo 4 with a setting or other way or am I out of luck. See attached pics for clarity.
