Creo Parametric 2.0: Add Taper Option to Extrusion Functionality
JamesWittes
Question for Creo expert users:
I'm cutting a 3-sided rectilinear notch into the periphery of a disc, and I
would like to know if the "add taper" option can be used to create 2
different taper angles, one angle applied to the 2 opposing sides of the
notch and another angle applied to the 3rd side.
Thanks in advance,
--Jim
James Wittes
Matthew James, LLC
Princeton, NJ
609-921-9056
Jim,
The Taper function is restricted to a single angle - no way to add multiples that I've ever been able to find. I believe you will have to create two separate draft features to accomplish what you are trying to do, one for the 2 opposing sides of the notch, and a separate one for the 3rd side
Mike Brattoli
Moen Incorporated
