Creo that i dowloaded shuted down and they ask me to report an error code. Thus, how can i get help.
Hi Cheikhna,
If you have maintenance, you can open a TS case here.
If not, please provide some detailed information as to what you did and what kind of error you ran into.
Amit
Hello Amit!
For instance , i dowloaded the program and i finished all the process . After i got the Creo Parametric on my desktop, i wanted to use it but each time i went in the page told me :"Creo parametric is shutting down because it couldn't run the quality agent, which is required in this edition, report error 0*06000003.
Thank You.
Please check out this thread for a solution to your issue: Creo 2.0 M200 Quality Agent Error
