DRAFT OVER 30°
  • November 12, 2014
  • 3 replies
  • 1467 views
hello,
is it possible to have a draft over 30° vith the command DRAFT?
thanks
    In Creo 3 it goes up to 89.9°.
    Yes; you'll want to upgrade to Creo 3 M010. It didn't appear that draft over 30 worked with the initial 3.0 release.
    .... and if you can't eject the part from the mold at 89.9 degrees, then there's something wrong with your part design
    Patriot_1776
    Bwahahaha! I remember when the draft stopped at, what, 7 degrees? Which is still WAY more than you should ever need. It's handy that it's more robust now, so you can cheat on certain geometry. I remember draft not working and having to instead sweep angled surfaces to use as cuts.
