Default template
  • December 7, 2010
  • 2 replies
  • 1068 views
Is there a way to uncheck 'Use default template'? This used to not be
on, and I'm not sure what I did to turn it on, but I can't find what I
need to change to turn it back off. Anyone?
Tony
    Thanx Mark for the quick comeback.
    No thanx PTC for the completely OBVIOUS setting name.
    T
    Config.pro option force_new_file_options_dialog yes will gray out the check mark box
    David Brainsky
    Chula Vista, Ca. 91910
