Delete a place holder 3D Printer
How do I delete this place holder 3D printer. The "Remove" option is grayed out.
Corey,
I'm not sure what is causing this error.
But you could try deleting the file where the information is stored and see if that clears the list.
In Windows Explorer, type %appdata%\Roaming\PTC\ProENGINEER\Wildfire\.wf\.Settings the print3d_prop.conf file has the information regarding the 3D printers.
Give that a try and let me know if that solves the issue for the time being.
Amit
Enter your E-mail address. We'll send you an e-mail with instructions to reset your password.
