Elastoplastic Curve Generation
  • July 3, 2013
  • 7743 views
Can anyone tell me the right way to enter the elastoplasic properties of a material in Creo/WF 5.0? I have the true stress/strain curve entered. With the "Use best fit coefficients checkmarked the curves look good. However the Tensile Yield stress is at 0. If I try to hit ok it doesn't let me. It says I must have a value greater than 0. If I uncheck the box and put in the correct value the curve shifts way up. Any thoughts?
    Best answer by SylvainA.
    I never used this capability of Pro/E, but I see that the graph is a plot of plastic strain vs stress.
    Thus it seems obvious that the curve starts after the yield stress point...
    SylvainA.1-VisitorAnswer
    Yes, only the part of the curve after yield should be used and should be true stress vs true strain.
    This is to likely to change with Creo3.0
    http://communities.ptc.com/message/195487#195487
    Regards
    Ok thanks. It is true stress and strue strain. Should I also use the equation you mentioned to convert true strain to plastic strain?
