Extruding to an angled face problem
  • December 16, 2009
  • 4231 views
Here is a problem I am sure someone will find easy to solve. I have a student trying to extrude sketch 2 (The red shape in the attached JBG file) from its current location to the angled face to its right. However, the shape of sketch 2 needs to follow the angle at the end of the object and stop 3 mm short of the angled face. Ideas? Thanks in advance BTW, i tried to attach the pro-e file (called angled_extrude.prt.1) and because of the .1 it will not attach. It is considered as not being one of the excepted extensions. However, everytime you save pro-e adds the number. Isthere a solution to this? Last tiem I emailed the file to one of the members.
    You can do an extrude to selected, and create a datum plane offset from the angled edge by the desired amount. Alternatively, and I'm just guessing by the appearance of the image, would a shell command be appropriate?
    Jim, It's a little hard to tell from your submission what's going on (what's solid, what's surface, etc.) In any case, there a many ways to do such things, probably two in particular. First create a surface which is offset "inward" by 3mm from the angled surface. Now either (1)create an extruded shape To Selected and pick the new surface, or (2) create an ordinary extrusion, pick its end surface afterward, then select Edit/Replace and again pick the new surface. You could also trim back a longer extrusion using the surface (Solidify). David
    JNiessen1-VisitorAuthor
    Here is one shot of different selections used in the extrude. I created a datum 1 then extruded as shown. Neither cut the extrusion off at an angle. I can't send the document with two shots pasted so I have to do two separate replies. See screen shots of extrudes #2 As for the shell command the face to the left of sketch 2 is a web. The piece has already been shelled to create what you see. We tried to create a shell for the piece on the right of sketch 2 then exclude the angled face and the sketch 2 face but it didn't work
