Font not publishing
  • March 11, 2008
  • 3 replies
  • 950 views
We have an issue where certain truetype fonts will publish and others will not. These are .ttf type files. An example would be Arial.ttf will publish and Arial Black.ttf will not. Any ideas?
    We had a lot of issues publishing truetype fonts as well. We ended up
    only using the standard Pro/E fonts and that has worked perfectly.
    Kevin Alexander
    You can use Pro-E defined TTF formats.If not i have a better work around.
    Update the config.pro with proe_font and map it to a directory where you can drop your custom fonts.
    Eventually update recipe file with Stroked All.
    This will fix the issue.
    Did you try putting the Custom fonts in Pro/E's text > font folder ?
    ~ Vaibhav
