Format issues (&PTC_WM_REVISION:D)
We have older formats that use the old Intralink parameter (&PROI_REVISION:D) that works just fine when you create a new dwg that's never been in Windburn, er, Windchill. I just updated our formats with a new corporate logo and updated the revision parameter to the Windchill rev parameter (&PTC_WM_REVISION:D) and the performance is buggy. When replacing the old format with the new format, it works fine. When creating a new dwg, the revision parameter string drops the "&", and sometimes the ":D" as well, and will no longer work. I double-checked our new and old .frm (format) files, and they're what should be correct, ("&" prefix and ":D" suffix), yet the old format works fine, and the new one doesn't. Is this glitch simply a Windchill thing? Are we going to have to deal with this every new dwg we make? Should I just use the old parameter because it actually still works?
WAAAY annoying.....
Any ideas?
Thanks!
