Hole tool - clearance hole standards
To all,
I have an engineer that is asking about the clearance hole diameter values that are pre-filled in the hole tool based on screw size nominal. Does someone know what standard these follow? The values in the hole tool follow the machinist handbook, but they do not agree with the ANSI/ASME values? I would appreciate your feedback....
Buddy Hudson
