How to create teeth on the curved surfaces of cylinder
  • October 30, 2015
  • 4 replies
  • 4036 views
Hi I want to create teeth on the curved surfaces. I tried projecting the teeth sketch on the curve it's showing error.
Here by I am attaching my model file for reference. Please help me out to resolve this.
    please upload your Creo part, not PDF ! And attach it to this discussion !
    MH
    Make the tooth-ridge solid and extrude/cut a single V.  Then pattern the V cut.
    Is this a functional gear or simply a tooth pattern?  What is the purpose of the model?  The what is the purpose of the part?  etc...
    Look for the wrap option (not warp). Create a cylinder surface and then wrap a datum curve that is the shape of the teeth onto it. Then create a variable section sweep driven by the edge of the cylinder and referencing the wrapped curve. Not going to guarantee it works; but that's what I would try.
    ...a few VSS options:
    svaidya1-VisitorAuthor
    Hi Antonius,
    Could you please attach Creo file for the same.
    Non swept version in Creo 2
