How to get an Parameter value of an *.prt to other *.prt
kkr-2
We have an requirement to prepare two models. The length of the second model is based on the volume of the first model.
How read an parameter output of one model as an  input parameter for the second
James62
(To:kkr-2)
Try using Session ID.
Shared Parameters
KenFarley
(To:kkr-2)
The only way I can think of is if both parts are in a common assembly. You can then use parameters from one part in relations to define things in another part. There is no way I know of to independently query information from another part from within a part.
