Import facet file with a textures
  • July 16, 2014
  • 1582 views
Hi!
Is there the way to import into Creo facet files with a textures. OBJ, VRM ???
    I found an internal article that says: Textures are not exported for *.obj and *.wrl files in Creo Parametric 2.0.
    This makes it very likely, we cannot import textures for those file types, either (although there can be differences between what is supported with import and with export).
