Interfaces in Mechanica
I have a plate sitting on top of two surfaces with a load applied to the top of the plate. I am trying to measure the displacement and stress on the two components holding the plate up. If I just mesh the model, it assumes the two pieces are bonded, which is incorrect. If I put rigid connections between some bolt holes on the parts and the plate, the plate flexes, but the load does not affect the other two parts. The same thing happens when I put interfaces between the contacting surfaces. Any ideas on how I can get my analysis to run correctly? Thanks.
