IpfcXToolkitGeneralError and IpfcXToolkitCantModify
  • August 31, 2014
  • 2 replies
  • 1220 views
    Jeremy,
    Can you check if the environment variables are set:
    - PRO_DIRECTORY = Pro/ENGINEER <load point=">
    - PRO_COMM_MSG_EXE = Full path of pro_comm_msg.exe
    Rochan Hegde
    Productspace Solutions Inc.
    kjl.cool1-VisitorAuthor
    Rochan,
    thank you for your solution.
    know i am not so sure about the variable PRO_DIRECTORY.
    i installed proe with default path, (PS:Windows 7, 64bit), i set PRO_DIRECTORY=C:\Program Files\proeWildfire 5.0\bin\
    cause in the computer which can run my app successfully, i set the same values.
    and whats more, now it always throwIpfcXToolkitCantModify, does it mean that i havent get anauthority?
    In Reply to Rochan Hegde:
    Jeremy,
    Rochan Hegde
