Merge Error
- April 26, 2017
- 1 reply
- 5523 views
Morning All
Could somebody have a look at the attached model and help me to understand the merge error. I've tried several iterations of this and I cannot clear this.
Many Thanks.
I've been playing with similar models to understand this error and it stems from the open edges. If I extrude a small shape perpendicular through another cylinder, merge & trim there is no error.
Offset the surface and the error appears so I think I understand what Creo is doing.
I need to close my section, merge & trim then delete the surfaces I don't need!
Enter your E-mail address. We'll send you an e-mail with instructions to reset your password.
