Overwriting Dimensions
  • November 19, 2008
  • 2 replies
  • 2392 views
Hi Sometimes I have the need to overwrite the dimensions. How do I go about doing this,because I tried to do it in the properties but it doesn't take away the original dimensions. Any help is appreciated Thanx
    REPLACE @D (dIM) W/ @O (OTHER) THEN ADD WHATEVER YOU WANT
    Thanx a million Jamie
    Dale_Rosema
    If you found an answer, don't forget to mark it as correct for those that follow behind and search on this topic.
    Thanks, Dale
    Theres is also a discussion on this with the title "How to show text instead of dimensions without overwriting?" which may help you..
