Parabolic curve
JeffTaylor
2-Explorer
Parabolic curve
I need to add a parabolic curve in sketcher, can someone tell me how to do this please.
Thanks in advance.
Jeff
Not directly in sketcher, but you can create a datum curve by equation.
You should then be able to reference that curve in another sketch and
revolve, etc...
Christopher F. Gosnell
FPD Company
124 Hidden Valley Road
McMurray, PA 15317
Use a Conic curve in sketcher, the parameter on the curve is Rho
You can modify rho as follows:
parabola, use the default value of 0.5.
For a hyperbola, type a value between 0.5 and 0.95.
You can also modify the angles at the ends of the curve
Sean
