Problem with dxf imported
  • March 23, 2016
  • 3 replies
  • 6283 views
Hello ,
I'm a new ptc Créo user. I want to import a dxf file and work on as a sketch. When I import my dxf file , ptc créo tell me this : " You tested too many entities in the draft. When the manager of intentions is active, the treatmentof so much of entities is likely to take much time.You can click on selecting to open under windowand to select the entities to be imported"
but I need everything in my dxf. Do you know a method to avoid this problem? ( I already change my DXF into DWG just for see and same problem !)
ps : sorry , my bad english
    Best answer by dgschaefer
    Can you break your DXF into several smaller files? Have you tried importing it directly into the part instead of sketcher?  That will create a curve that you can then reference for later features.  I've never had issues with importing large numbers of DXF entities directly into a part file.
    ok I just find the button to import directly into "part" . A thousand thanks !
    I agree with Doug. Import your DXF in to the part. you won't have to deal with the intent manager wanting to change DXF geometry and you won't have entity limitations.
    I have the same issue sir.
    I want to use the dxf file as geometric reference to create a new part file. when i am trying to import the dxf into part file, it scales to higher value. how can i solve this?
    thanks in advance.
