Cxxx are preproduction releases F000 is the initial production release Mxxx are maintenance releases of an F000 release Pro/E can be installed from any CD set, Cxxx, F000 or Mxxx. Windchill may require a mix of F000 CD's and the Mxxx build that you are installing. Ben Loosli Sr IS Technologist Engineering Automation Systems L-3 Communications/Integrated Systems Waco, TX 76715 254-867-4069 -
