SAT (ACIS) files from FARO
PierrePatenaude
3-Newcomer
I need to import .SAT files (ACIS) into ProE WF3. These come from a FARO arm (probe). I can only import the planes, but lines and points don't translate. Anybody can help?
1 REPLY 1
Hi Pierre, I don't think you can directly translate ACIS files but I normally use one of the free ACIS to STEP converters which you can download form the Web (there used to be an online translator called "The STEP Repository" I think which used to upload ACIS and you could then download STEP. Once you have the STEP file you can import it into W3. Hope this helps? Regards Paul
