Skeleton files, Creo3.0
jsawyer
Are skeleton file not used in Creo3.0? I can't find the command. Skeleton is not a keywork in serch.
5 REPLIES 5
dschenken
(To:jsawyer)
It would be odd if it's not there. It's a subtype of part, as in New -> Part - Skeleton or Part - Bulk Item.
I guess skeleton model can be created in Assembly mode, only.
MH
Martin Hanák
Yes, Skeleton parts can only be created within the context of an assy.  It's always been that way, I believe.
And they are still in Creo 3, assuming you have an AAX license.
LinkedIn
jsawyer
(To:jsawyer)
Thankyou, I did find it where David said it would be. I just had a bran fart, Thanks again
Mahesh_Sharma
22-Sapphire I
(To:jsawyer)
James,
You may mark David's reply to post as correct answer as that helped you
