Spoiler Alert: Want to know what Creo apps we plan to release?
  • February 7, 2011
  • 6032 views
Want to explore the evolution of Creo? Interested in the future roadmap for Creo Elements? Get the sneak peak on the Creo branding and the Creo product direction by downloading a new ebook available today, February 7th, on PTC.com
Download the free ebook
    Interesting roadmap.
    Do you have any information about the Creo\elements\direct and Creo\elements\pro additional modules like sheet metal, cabling, surfacing, etc.....?
    Will PTC merge some of these in Creo or each solution will keep the own one?
    regards
    Hi Carlo,
    As has been described in the ebook - PTC will continue to develop and plans to offer several major releases of Creo Elements/Direct and its related modules over the next few years, as a stand-alone direct modeling solution. This approach provides new capabilities for existing customers of that solution, while simultaneously enhancing the new Creo app for direct modeling. These new releases of Creo Elements/Direct will include the new, top-level Ribbon UI, consistent with the new Creo apps, as well as improvements to the integration with Windchill®.
    Creo 1.0 will initially support seamless data migration for geometry and geometric meta-data from Creo Elements/Direct 17.0 and 18.0, as well as previous CoCreate releases. Creo Elements/Direct 18.1 will enable additional migration of more application-specific data to Creo. And, in the following releases, more and more data will be able to be migrated to Creo. This phased approach will, over time, allow customers of Creo Elements/Direct to achieve upward compatibility with the new Creo direct modeling app built on the common data model. It is off course an optional migration, and customers will chose if and when they move to Creo based on the benefits they see.
    With respect to additional modules or extensions, the main focus will be to leverage the best from ‘similar’ modules, and indeed have modules that can be used together with either the Creo direct model app or Creo parametric app. This offcourse will happen over a number of releases, beyond Creo 1.0.
    I hope this helps.
    Best Regards,
    Geoff
    I have a simple question that I can never get a direct answer for yet.
    Is CREO 1.0 a new CAD software developed from the ground up with new code and engine?
    Everywhere I go, everyone is talking about the migration path and the renaming of Wildfire products has confused many people. IS CREO a new CAD Software that simply can read in native Pro/E files, or is it some kind of enhanced version of Pro/E that looks different.
    I want a straight answer.
    Forget about the Creo elements/pro naming stuff. I simply want to know if CREO 1.0 is a new CAD software built from the ground up.
