Transparent View
Can anyone tell me if Transparent View is available in CREO 2.0 Parametrics? When I expand Display Style I do not see Transparent as an option.
Oh, you must be in a part. If that's the case then you need to do #3 above which is fine if it's a part. Not so much if it's an assembly.
For uploading an image, If you are on windows 7 you can use the Snipping Tool and save the file where you can upload it. If you use alt+printscreen then paste it into paint and save the file for upload later.
For #1 (and assemblies) use the Style tab in the view manager. Click on style tab, then new, then component display style select the transparent button.
As for #2 (and assemblies) it's located in the image below. Make sure you select a part first before you follow the links otherwise it will be greyed out as in the image below:
Enter your E-mail address. We'll send you an e-mail with instructions to reset your password.
