i want to inspect my geometry using reflection. but when i click inspect the reflection option is not highlighed.
That is strange. Care to share the file to see if it is your SW installation? If it fails on other machines, you may need to file a support case. If it is only on your machine, it may be an installation corruption.
how can i upload now
Use the advanced editor... upper right of the reply UI
thanks for guiding me..i am new to this forum...
all right....may be my installation problem....thanks for your time...
Works on mine also; Creo 2.0 M040.
Nice work on the tube union!
Thank you sir....just learning creo now...![]()
