Unverified family tree in creo 2.0
Hello everyone,
I have made family table in which i verify one model in family tree after i changed the dimension then it shows unverified,it restrict to save the file.
anyone have any idea?
Vishal Prajapati
Hello everyone,
Vishal Prajapati
If you change a dimension that affects all the other instances, then all the other instances need to be verified. You can do this from the family table menu or by opening and regenerating every instance separately.
I believe there is no 'auto-verify.'
Family tables are typically used for parts which don't change, such as fasteners. If there was an 'auto-verify' Creo would have to regenerate the full set of instance for any change you made, a large waste of time.
As long as you are developing a model associated with a family table, get used to opening the generic and using Verify. You can make as many changes as you like and then Verify only once before saving it.
Enter your E-mail address. We'll send you an e-mail with instructions to reset your password.
