Variable chamfer like a variable round?
mdebower
18-Opal
Wildfire 5.0 / Creo Elements Pro 5.0
Is there any way to make a variable chamfer like a variable round? I poked around the chamfer command, looked at the help files, searched both the exploder, and the community and didn't really see anything...
-marc
1 REPLY 1
gbon
(To:mdebower)
Depending of your geometry, perhaps you could:
- make a variable round.
- make a sweep surface between the 2 generated curves by the round feature.
- extend this surface if necessary on 4 boundaries.
- make a cut with this surface.
De : Marc DeBower [
