Community Tip - Did you get called away in the middle of writing a post? Don't worry you can find your unfinished post later in the Drafts section of your profile page.
X
You can define a pressure field by equation. For water, the pressure would be a function of the distance below the water surface (P = rho×G×h). You may need the Advanced licence of Mechanica for this... HTH!
