In Proe 4.0, enter the "Independent geometry", there is a command "Geometry==>Collapse Geometry", but in Creo 1.0, I can't find it,
Can anyone kindly help me?
Hi
For those who have never used this option;
See the following example to know some of its its utilities
K.Mahanta
I haven't it really used it but I think you want to be in the Import Data Doctor (IDD) environement of the Independent Geometry feature definition. By default it enters the Scan Tools environment.
I can find "Collapse Geometry" in Proe 4.0 menu, but I can't find it in Creo 1.0. This command is useful for me, following picture for reference.
The Import Data Doctor (IDD) is used for repair import data.
Hi
Try to use command search to find this option
This option is under editing tab
This option is is still available but not in Geometry tab
K.Mahanta
Hi
K.Mahanta
Hi Mahanta:
Thanks very much for your answer. I used this method to manage the "reference geometry", I have find this command and check you method. it is correct.
