calculate deformation at flexible of a rubber plate
  • August 13, 2007
  • 0 replies
  • 935 views
Hi. Excuse for mine English. At me such problem. It is necessary to calculate deformation at flexible of an outside layer of a rubber plate. Thickness of a plate of 2 millimeters, corner of a bend 160 - 170 degrees. Where the neutral line will be located? Size of Factor the At - factor what? Thank for the help.
