cam-follower connection
lylebeidler
Can someone please explain what the purpose of the Front & Back references
are for a cam follower connection? My colleague is having some trouble with
it, and the help files aren't much use.
Lyle Beidler
MGS Inc
178 Muddy Creek Church Rd
Denver PA 17517
717-336-7528
Fax 717-336-0514
<">mailto:-> -
<">http://www.mgsincorporated.com>
I will try. WF4.0 FWIW
If the surface you choose as the contact surface on a cam is part of a cylinder or similar curved shape then the direct on the line of contact is clear - i.e. parallel to the "axis" of the curve. In this case you can have Automatic for Depth Display.
If the cam or follower surface is a plane then there is no implication of direction so you have to provide this by picking a couple of reference points being the ends of the line across which contact is to be made.
John Prentice
Hopefully attached will get through - it is the cam connection from the arm of a ball valve and the flat face of the valve plunger. The blue ring shows the Front ref point.
